Cause :Â Grounding shortcut fault 1 comes when an ground fault overcurrent flows due to an earth fault that occurred on the inverter's output side (load side).
A "ETH1" Grounding shortcut fault 1 in GD20 drive refers to unintentional electrical connection between the drive electrical components and the ground (earth). When this happens, current flows through an unintended path, posing safety hazards and potentially damaging the VSD or other connected equipment.
1. Check whether the electric motor insulation is weakening.
2. Check whether the wiring between the frequency converter and the electric motor is damaged.
3. Check if the connection of the motor is normal or not.
