INVT GD20 Series, GD20-EU Series, GD20-UL Series & GD20-LA Series Drive
330
Apr 13, 2024 9:33 am
Cause : Autotuning fault comes when the motor capacity does not comply with the inverter capability and the rated parameter of the motor does not set correctly.
- The offset between the parameters from autotune and the standard parameter is huge.
- Change the inverter mode.
- Set the rated parameter according to the motor name plate.
- Check the motor connection and set the parameter.
