Difference between LAN & WAN?
LAN (Local Area Network) and WAN (Wide Area Network) are two types of networks used in computer communication. Here are the key differences between them:
  1. Scope:
    • LAN: A LAN covers a relatively small geographic area, such as a single building, office, or campus. It typically serves users who are located in close proximity to each other.
    • WAN: A WAN covers a larger geographic area, often spanning multiple cities, countries, or even continents. It connects LANs and other smaller networks over long distances.
  2. Ownership and Control:
    • LAN: LANs are usually privately owned and controlled by a single organization, such as a business, school, or government agency.
    • WAN: WANs may be privately owned or operated by telecommunication companies, ISPs (Internet Service Providers), or other network providers. They are often shared among multiple organizations or users.
  3. Technology:
    • LAN: LANs typically use high-speed technologies such as Ethernet, Wi-Fi, or Token Ring for communication within a local area. They often have high bandwidth and low latency.
    • WAN: WANs use various technologies for long-distance communication, including leased lines, fiber optics, satellite links, and packet-switched networks like the Internet. WAN technologies are designed to handle communication over longer distances and may have lower bandwidth and higher latency compared to LANs.
  4. Topology:
    • LAN: LANs usually have a bus, ring, or star topology, where devices are connected to a central switch or hub within a confined area.
    • WAN: WANs can have various topologies, including point-to-point, hub-and-spoke, and mesh topologies, depending on the network architecture and requirements.
  5. Cost:
    • LAN: LANs are typically less expensive to set up and maintain compared to WANs since they cover smaller areas and require less infrastructure.
    • WAN: WANs often involve higher costs due to the need for long-distance communication links, specialized equipment, and ongoing maintenance.
  6. Security:
    • LAN: LANs are generally considered more secure than WANs because they are confined to a single organization's premises and can be more easily controlled and monitored.
    • WAN: WANs are more vulnerable to security threats such as eavesdropping, hacking, and malware attacks due to the larger network footprint and the involvement of multiple parties.
In summary, LANs are smaller, privately owned networks used for local communication within a limited area, while WANs are larger, often publicly shared networks used for long-distance communication between geographically dispersed locations.
