Serial communication and RS 232
Serial communication is a method of transmitting data between devices one bit at a time over a single wire or pair of wires. It is commonly used in various applications, including industrial automation, telecommunications, and computer peripherals. RS-232 (Recommended Standard 232) is a standard for serial communication that defines the electrical and mechanical characteristics of the interface.
Here's an overview of serial communication and RS-232:
Serial Communication:
  • In serial communication, data is transmitted sequentially, one bit at a time, over a single wire or pair of wires.
  • It typically uses two signal lines: one for transmitting data (TX) and one for receiving data (RX).
  • Serial communication can be synchronous or asynchronous. In synchronous communication, a clock signal is used to synchronize the transmission and reception of data. In asynchronous communication, start and stop bits are used to delineate data frames.
  • Serial communication is widely used in various applications due to its simplicity, low cost, and ease of implementation.
RS-232:
  • RS-232 is a standard for serial communication that was introduced by the Electronic Industries Association (EIA) in the 1960s.
  • It defines the electrical characteristics of the interface, including voltage levels, signal levels, and connector pin assignments.
  • RS-232 specifies the use of voltage levels of +3 to +15 volts for logic 0 (mark) and -3 to -15 volts for logic 1 (space).
  • RS-232 interfaces use a 9-pin or 25-pin D-sub connector, with the pinout standardized for different functions such as data transmission, control signals, and ground.
  • RS-232 supports asynchronous communication at various baud rates (bits per second), typically ranging from 300 baud to 115,200 baud.
  • RS-232 is commonly used to connect devices such as modems, printers, barcode scanners, and other peripherals to computers and other control systems.
While RS-232 has been widely used for serial communication in the past, it has largely been replaced by newer standards such as USB (Universal Serial Bus) and Ethernet in modern computing and communication systems. However, RS-232 is still commonly used in industrial applications and legacy systems due to its simplicity and robustness. Additionally, RS-232-to-USB converters and other adapters are available to interface RS-232 devices with modern computers and devices that lack native RS-232 ports.
