What are the difference between Unmanaged Switch and Manged switch?
Unmanaged switches and managed switches are both types of network switches used to connect devices within a local area network (LAN). However, they differ in their capabilities, features, and management options. Here are the key differences between unmanaged switches and managed switches:
Unmanaged Switch:
  1. Basic Functionality: Unmanaged switches are plug-and-play devices that operate out of the box with no configuration required. They provide basic network connectivity and forward data packets between devices connected to the switch.
  2. No Configuration Options: Unmanaged switches do not offer configuration options or management features. They operate using default settings and do not support features such as VLANs (Virtual Local Area Networks), Quality of Service (QoS), or port mirroring.
  3. Simple and Affordable: Unmanaged switches are typically simple in design and functionality, making them easy to set up and use. They are suitable for small networks or home use where basic connectivity is sufficient. Unmanaged switches are often more affordable compared to managed switches.
  4. Limited Control and Visibility: Unmanaged switches provide limited control and visibility over network traffic. Administrators cannot monitor or manage individual ports or configure advanced features such as traffic prioritization or security settings.
  5. No Remote Management: Unmanaged switches do not support remote management capabilities. Administrators cannot access the switch remotely to monitor or configure settings.
Managed Switch:
  1. Advanced Features: Managed switches offer advanced features and configuration options that allow administrators to customize and optimize network performance. These features may include VLAN support, QoS, port mirroring, link aggregation, SNMP (Simple Network Management Protocol) monitoring, and access control lists (ACLs).
  2. Configuration Options: Managed switches provide a web-based interface, command-line interface (CLI), or specialized management software for configuring and managing switch settings. Administrators can configure individual ports, monitor network traffic, and implement security policies based on specific requirements.
  3. Greater Control and Visibility: Managed switches offer greater control and visibility over network traffic compared to unmanaged switches. Administrators can monitor bandwidth usage, troubleshoot connectivity issues, and implement policies to prioritize critical traffic.
  4. Enhanced Security: Managed switches support advanced security features such as MAC address filtering, port security, and authentication mechanisms. Administrators can enforce security policies to prevent unauthorized access and protect sensitive data.
  5. Remote Management: Managed switches support remote management capabilities, allowing administrators to access and configure the switch from anywhere with an internet connection. This enables centralized management of distributed networks and facilitates proactive monitoring and troubleshooting.
In summary, the main differences between unmanaged switches and managed switches lie in their functionality, configuration options, management capabilities, and level of control over network traffic. Unmanaged switches are simple, easy to use, and cost-effective but lack advanced features and management options. Managed switches offer greater flexibility, customization, and control over network operations but require more expertise to configure and manage effectively. The choice between an unmanaged switch and a managed switch depends on the specific requirements and complexity of the network environment.
