What is DeviceNet ? Basics of DeviceNet
DeviceNet is a network protocol used in industrial automation for connecting and communicating between devices such as sensors, actuators, motor controllers, and other industrial equipment. It is developed by ODVA (Open DeviceNet Vendor Association) and is based on the Common Industrial Protocol (CIP), which also includes EtherNet/IP and ControlNet.
Here are some basics of DeviceNet:
  1. Physical Layer: DeviceNet uses a two-wire, shielded twisted-pair cable for communication between devices. It operates at data rates of 125 kbps, 250 kbps, or 500 kbps, depending on the network configuration and requirements.
  2. Topology: DeviceNet networks typically use a trunk-line/drop-line topology, where devices are connected in a linear fashion along the trunk cable, with drop lines branching off to connect individual devices. This topology allows for easy addition and removal of devices without disrupting the entire network.
  3. Network Architecture: DeviceNet follows a master-slave communication model, where one device (typically a programmable logic controller or PLC) acts as the master or scanner, controlling communication with multiple slave devices on the network. Slave devices, such as sensors and actuators, respond to commands from the master and provide data or perform actions as required.
  4. Communication Protocol: DeviceNet uses a producer-consumer communication model, where devices known as producers publish data onto the network, and other devices known as consumers subscribe to this data and receive updates as it becomes available. This allows for efficient and deterministic communication between devices on the network.
  5. Device Identification: Each DeviceNet device is assigned a unique node address, which is used by the master device to identify and communicate with individual devices on the network. This addressing scheme allows for easy configuration and management of the network.
  6. Configuration and Diagnosis: DeviceNet networks can be configured and diagnosed using configuration tools and software provided by device vendors or third-party software tools. Configuration parameters such as node addresses, baud rates, and communication settings can be set using these tools, and diagnostic information such as device status and network health can be monitored and analyzed.
  7. Compatibility: DeviceNet is a widely used and well-established protocol in industrial automation, supported by a large number of device vendors and manufacturers. It is interoperable with other protocols such as EtherNet/IP and ControlNet, allowing for seamless integration with existing automation systems.
In summary, DeviceNet is a versatile and reliable network protocol used in industrial automation for connecting and communicating between devices. Its robust communication features, deterministic performance, and ease of configuration make it suitable for a wide range of applications in manufacturing, process control, and other industrial settings.
