What is the difference between Modbus RTU and Modbus TCP?
Modbus is a popular communication protocol used in industrial automation for transmitting data between electronic devices. Modbus RTU (Remote Terminal Unit) and Modbus TCP (Transmission Control Protocol) are two variants of the Modbus protocol, each designed for specific network environments. Here's the difference between Modbus RTU and Modbus TCP:
  1. Physical Layer:
    • Modbus RTU: Modbus RTU is based on serial communication and typically uses RS-232 or RS-485 serial ports for communication. It employs a master-slave architecture, where a single master device communicates with multiple slave devices over a serial connection.
    • Modbus TCP: Modbus TCP is based on Ethernet communication and operates over TCP/IP networks. It uses standard Ethernet cables and network infrastructure to communicate between devices. Modbus TCP allows devices to communicate directly over Ethernet networks, eliminating the need for serial ports and serial communication protocols.
  2. Data Transmission:
    • Modbus RTU: Modbus RTU uses binary encoding to transmit data packets in a compact and efficient format over serial communication links. It supports asynchronous serial communication with configurable baud rates and data formats.
    • Modbus TCP: Modbus TCP encapsulates Modbus RTU packets within TCP/IP packets for transmission over Ethernet networks. It uses standard TCP/IP sockets for communication, allowing devices to exchange data using familiar networking protocols.
  3. Speed and Distance:
    • Modbus RTU: Modbus RTU operates at lower speeds compared to Modbus TCP, typically ranging from 1200 bps (bits per second) to 115200 bps, depending on the baud rate settings. It supports longer communication distances, especially when using RS-485 serial ports.
    • Modbus TCP: Modbus TCP operates at higher speeds, with data rates of 10 Mbps, 100 Mbps, or 1 Gbps, depending on the Ethernet network infrastructure. It is suitable for high-speed communication over local area networks (LANs) and offers faster data transfer rates compared to Modbus RTU.
  4. Network Configuration:
    • Modbus RTU: Modbus RTU requires point-to-point or multi-drop serial connections between devices using RS-232 or RS-485 serial ports. It may require additional hardware, such as serial converters or repeaters, to extend communication distances.
    • Modbus TCP: Modbus TCP operates over standard Ethernet networks using TCP/IP protocols. It supports star, ring, or mesh network topologies and allows devices to communicate directly over Ethernet switches or routers without additional hardware.
In summary, the main difference between Modbus RTU and Modbus TCP lies in their physical layer and network configuration. Modbus RTU is based on serial communication and is suitable for point-to-point or multi-drop serial connections, while Modbus TCP operates over Ethernet networks and supports higher-speed communication over standard TCP/IP protocols. The choice between Modbus RTU and Modbus TCP depends on the specific requirements of the application, including communication speed, distance, and network infrastructure.
