What is the Difference between ProfiNet and DeviceNet?
ProfiNet and DeviceNet are both industrial network protocols used in automation and control systems, but they have several differences in terms of their underlying technology, communication characteristics, and application areas. Here are the key differences between ProfiNet and DeviceNet:
  1. Technology:
    • ProfiNet: ProfiNet is an Ethernet-based industrial network protocol developed by Siemens. It operates on standard Ethernet hardware, such as Ethernet switches and network interface cards (NICs), and uses TCP/IP as its transport protocol. ProfiNet supports both real-time (ProfiNet RT) and non-real-time (ProfiNet IO) communication modes.
    • DeviceNet: DeviceNet is a fieldbus-based industrial network protocol developed by Allen-Bradley (now Rockwell Automation). It is based on the Controller Area Network (CAN) technology and uses a multi-drop bus topology with RS-485 physical layer for communication between devices.
  2. Communication Characteristics:
    • ProfiNet: ProfiNet supports high-speed communication over Ethernet networks, with data rates of up to 100 Mbps or more. It offers deterministic and real-time communication capabilities suitable for demanding industrial applications, such as motion control, process automation, and high-speed data exchange.
    • DeviceNet: DeviceNet operates at lower data rates compared to ProfiNet, typically ranging from 125 kbps to 500 kbps. It provides asynchronous communication with event-driven messaging and supports cyclic and acyclic data exchange between devices.
  3. Topology and Wiring:
    • ProfiNet: ProfiNet networks can be configured in various topologies, including star, ring, line, and tree topologies, using standard Ethernet cabling (e.g., twisted-pair, fiber optic). ProfiNet networks can also utilize Industrial Ethernet switches for network segmentation and redundancy.
    • DeviceNet: DeviceNet networks use a multi-drop bus topology, where devices are connected in series along a single communication cable. DeviceNet typically uses shielded twisted-pair (STP) or unshielded twisted-pair (UTP) cables with screw-type connectors (often referred to as DeviceNet drops).
  4. Manufacturers and Ecosystem:
    • ProfiNet: ProfiNet is primarily associated with Siemens, but it is an open standard supported by many other manufacturers and organizations, including the Profibus & Profinet International (PI) consortium. ProfiNet-compatible devices are available from various vendors, offering interoperability and flexibility in system integration.
    • DeviceNet: DeviceNet was developed by Allen-Bradley (Rockwell Automation) and is widely used in their automation products. While DeviceNet devices are available from multiple vendors, the protocol is closely associated with Rockwell Automation's ControlLogix and other automation platforms.
  5. Applications:
    • ProfiNet: ProfiNet is suitable for a wide range of industrial applications, including factory automation, process control, robotics, machine vision, and distributed control systems. It is commonly used in high-performance applications that require real-time communication and high-speed data exchange.
    • DeviceNet: DeviceNet is commonly used in industrial automation applications for connecting sensors, actuators, motor drives, and other field devices to PLCs (Programmable Logic Controllers) and control systems. It is widely used in manufacturing, material handling, and automotive industries for control and monitoring purposes.
In summary, ProfiNet and DeviceNet are both industrial network protocols used in automation and control systems, but they differ in terms of underlying technology, communication characteristics, topology, manufacturers, and applications. ProfiNet is Ethernet-based with high-speed communication capabilities, while DeviceNet is fieldbus-based with multi-drop bus topology and lower data rates. The choice between ProfiNet and DeviceNet depends on factors such as network requirements, application needs, and compatibility with existing systems.
