What is VLAN and How Does it Works?
A VLAN (Virtual Local Area Network) is a logical grouping of network devices and resources, regardless of their physical location, that communicate with each other as if they were on the same physical network segment. VLANs are created to enhance network security, performance, and management flexibility. Here's how VLANs work:
  1. Logical Segmentation:
    • VLANs allow you to segment your network logically, dividing it into separate broadcast domains.
    • Devices within the same VLAN can communicate with each other as if they were connected to the same physical switch, even if they are physically located on different switches.
  2. Traffic Isolation:
    • VLANs provide traffic isolation between different groups of users or resources.
    • Traffic within a VLAN stays within that VLAN and is not forwarded to other VLANs unless specifically configured to do so.
  3. Configuration:
    • VLANs are configured at the switch level by assigning specific switch ports to a particular VLAN.
    • Each switch port can be assigned to only one VLAN at a time, although some switches support trunking, which allows a single port to carry traffic for multiple VLANs.
  4. VLAN Tagging:
    • VLAN tagging is a method used to identify VLAN membership of frames as they traverse a network.
    • When a frame leaves a switch port configured for VLANs, a VLAN tag is added to the Ethernet frame header, indicating the VLAN to which the frame belongs.
    • This tagging allows switches and routers to forward traffic to the appropriate VLANs based on the VLAN tag.
  5. Inter-VLAN Routing:
    • By default, devices within the same VLAN can communicate with each other, but communication between devices in different VLANs is blocked.
    • Inter-VLAN routing is required to allow communication between devices in different VLANs.
    • This can be achieved by using a router or a layer 3 switch to route traffic between VLANs.
  6. Benefits:
    • Improved security: VLANs can isolate sensitive or critical resources from other parts of the network, reducing the risk of unauthorized access or attacks.
    • Enhanced performance: VLANs can reduce network congestion by segregating traffic and optimizing bandwidth usage.
    • Simplified management: VLANs enable easier management of network resources by logically grouping devices based on their function, location, or organizational structure.
In summary, VLANs provide a flexible and scalable way to segment a network, improving security, performance, and manageability by logically grouping devices and resources into separate broadcast domains.
