Lenze 8400 high line fault codes
Lenze 8400 high line fault codes: Find a comprehensive list of fault codes, their meanings, and solutions. This guide helps you quickly diagnose and resolve drive errors, including overvoltage, undervoltage, motor issues, communication faults, and more. Get your Lenze 8400 High Line back up and running efficiently.
Below list shows Lenze 8400 high line fault codes:
Error number Error message Response can be set in CAN Emergency Error Code
32 bits 16 bitshex 16 bitsdec (Lenze setting)
4xx.0125.00001 0x1901 6401 An01: AIN1_I < 4 mA TroubleQuickStop C00598/1 0xF000
4xx.0125.00002 0x1902 6402 An02: AIN2_I < 4 mA TroubleQuickStop C00598/2 0xF000
4xx.0131.00006 0x1f06 7942 CA06: CAN CRC error No Reaction C00592/1 0x8000
4xx.0131.00007 0x1f07 7943 CA07: CAN bus warn No Reaction C00592/3 0x8000
4xx.0131.00008 0x1f08 7944 CA08: CAN Bus Stopped No Reaction C00592/4 0x8000
4xx.0131.00011 0x1f0b 7947 CA0b: CAN HeartBeatEvent No Reaction C00592/5 0x8130
4xx.0131.00015 0x1f0f 7951 CA0F: CAN control word Fault C00594/2 0xF000
4xx.0127.00002 0x1b02 6914 CE04: MCI communication error No Reaction C01501/1 0x7000
4xx.0127.00015 0x1b0f 6927 CE0F: MCI control word Fault C00594/2 0xF000
4xx.0135.00001 0x2301 8961 CE1: CAN RPDO1 No Reaction C00593/1 0x8100
4xx.0135.00002 0x2302 8962 CE2: CAN RPDO2 No Reaction C00593/2 0x8100
4xx.0135.00003 0x2303 8963 CE3: CAN RPDO3 No Reaction C00593/3 0x8100
4xx.0131.00000 0x1f00 7936 CE4: CAN Bus Off No Reaction C00592/2 0x8000
4xx.0184.00001 0x5401 21505 Ck01: Pos. HW limit switch TroubleQuickStop C00595/1 0x8600
4xx.0184.00002 0x5402 21506 Ck02: Neg. HW limit switch TroubleQuickStop C00595/2 0x8600
4xx.0184.00007 0x5407 21511 Ck03: Pos. SW limit position TroubleQuickStop C00595/3 0x8600
4xx.0184.00008 0x5408 21512 Ck04: Neg. SW limit position TroubleQuickStop C00595/4 0x8600
4xx.0184.00153 0x5499 21657 Ck05: Error following error 1 Warning C00595/5 0x8611
4xx.0184.00154 0x549a 21658 Ck06: Following Error 2 Warning C00595/6 0x8611
4xx.0184.00155 0x549b 21659 Ck07: Travel range limit exceeded TroubleQuickStop C00595/7 0x8612
4xx.0184.00156 0x549c 21660 Ck08: Home position unknown WarningLocked C00595/8 0x8612
4xx.0184.08005 0x54cd 21709 Ck09: Positioning mode invalid WarningLocked C00595/9 0x8600
4xx.0184.08007 0x54cf 21711 Ck10: Profile data implausible WarningLocked C00595/10 0x8600
4xx.0184.08009 0x54d1 21713 Ck11: Operating mode invalid Warning C00595/11 0x8600
4xx.0184.08014 0x54d6 21718 Ck12: Profile no. invalid WarningLocked C00595/12 0x8600
4xx.0184.08015 0x54d7 21719 Ck13: Error FB MCKCtrlInterface Warning C00595/13 0x8600
4xx.0184.00015 0x540f 21519 Ck14: Target position beyond SW limit position WarningLocked C00595/14 0x8600
4xx.0184.00005 0x5405 21509 Ck15: Error status sign. brake Fault - 0x8600
4xx.0184.00064 0x5440 21568 Ck16: Time overflow manual control Fault -
4xx.0140.00013 0x280d 10253 Cl01: Module missing/incompatible No Reaction C01501/2 0x7000
4xx.0135.00004 0x2304 8964 CP04: CAN RPDO4 No Reaction C00593/4 0x8100
4xx.0145.00035 0x2d23 11555 dF10: AutoTrip Reset Fault C00189 0xF000
4xx.0145.00014 0x2d0e 11534 dF14: SW/HW invalid Fault -
4xx.0145.00024 0x2d18 11544 dF18: BU RCOM error Fault - 0x6100
4xx.0145.00033 0x2d21 11553 dF21: BU Watchdog Fault - 0x6100
4xx.0145.00034 0x2d22 11554 dF22: CU watchdog Fault - 0x6100
4xx.0145.00025 0x2d19 11545 dF25: CU RCOM error Fault - 0x6100
4xx.0145.00026 0x2d1a 11546 dF26: Appl. watchdog No Reaction C00580/1 0x6200
4xx.0145.00050 0x2d32 11570 dF50: Retain error Fault - 0x6100
4xx.0145.00051 0x2d33 11571 dF51: CuCcr error Fault - 0x6100
4xx.0145.00052 0x2d34 11572 dF52: BuCcr error Fault - 0x6100
4xx.0400.00009 0x1a09 6665 dH09: EEPROM power section Fault - 0x5530
4xx.0400.00016 0x1a10 6672 dH10: Fan failure Warning C00566 0x5000
4xx.0400.00104 0x1a68 6760 dH68: Adjustment data error CU Fault - 0x5530
4xx.0400.00105 0x1a69 6761 dH69: Adjustment data error BU Fault - 0x5530
4xx.0123.00094 0x175e 5982 FC01: Switching frequency reduction No Reaction C00590 0x2000
4xx.0123.00095 0x175f 5983 FC02: Maximum speed for Fchop No Reaction C00588 0xF000
4xx.0123.00099 0x1763 5987 FC03: Field controller limitation No Reaction C00570/4 0xF000
4xx.0123.00057 0x1739 5945 Id1: Motor data identification error WarningLocked - 0xF000
4xx.0123.00058 0x173a 5946 Id3: CINH motor data identification WarningLocked - 0xF000
4xx.0123.00059 0x173b 5947 Id4: Resistance identification error Warning - 0xF000
4xx.0123.00074 0x174a 5962 Id5: Pole position identification error Fault C00643/1
4xx.0123.00145 0x1791 6033 LP1: Motor phase failure No Reaction C00597 0x3000
4xx.0123.00015 0x170f 5903 LU: DC bus undervoltage Trouble C00600/1 0x3100
4xx.0123.00016 0x1710 5904 oC1: Power section - short circuit Fault - 0x2000
4xx.0123.00017 0x1711 5905 oC2: Power section - earth fault Fault - 0x2000
4xx.0119.00050 0x1332 4914 oC5: Ixt overload Warning C00604 0x2000
4xx.0123.00105 0x1769 5993 oC6: I2xt motor overload Warning C00606 0x2000
4xx.0123.00007 0x1707 5895 oC7: Motor overcurrent Fault - 0x2000
4xx.0123.00030 0x171e 5918 oC10: Maximum current reached Fault - 0x2000
4xx.0123.00071 0x1747 5959 oC11: Clamp operation active Fault - 0xF000
4xx.0123.00065 0x1741 5953 oC12: I2xt brake resistor overload Fault - 0xF000
4xx.0123.00090 0x175a 5978 oC13: Maximum current for Fch exceeded Fault - 0xF000
4xx.0123.00096 0x1760 5984 oC14: Direct-axis current controller limitation No Reaction C00570/1 0xF000
4xx.0123.00097 0x1761 5985 oC15: Cross current controller limitation No Reaction C00570/2 0xF000
4xx.0123.00098 0x1762 5986 oC16: Torque controller limitation No Reaction C00570/3 0xF000
4xx.0123.00031 0x171f 5919 oC17: Clamp sets pulse inhibit No Reaction C00569/1 0xF000
4xx.0119.00001 0x1301 4865 oH1: Heatsink overtemperature Fault - 0x4000
4xx.0119.00015 0x130f 4879 oH3: Motor temperature (X106) triggered Fault C00585 0x4000
4xx.0119.00000 0x1300 4864 oH4: Heatsink temp. > shutdown temp. -5°C No Reaction C00582 0x4000
4xx.0123.00032 0x1720 5920 oS1: Maximum speed limit reached No Reaction C00579 0x8400
4xx.0123.00033 0x1721 5921 oS2: Max. motor speed Fault - 0x8400
4xx.0123.00001 0x1701 5889 ot1: Max. torque reached No Reaction C00608 0x8300
4xx.0123.00093 0x175d 5981 ot2: Speed controller output limited No Reaction C00567 0xF000
4xx.0123.00014 0x170e 5902 OU: DC bus overvoltage Trouble - 0x3100
4xx.0144.00001 0x2c01 11265 PS01: No memory module Warning - 0x6300
4xx.0144.00002 0x2c02 11266 PS02: Invalid par. set Fault - 0x6300
4xx.0144.00003 0x2c03 11267 PS03: Invalid device par. set Fault - 0x6300
4xx.0144.00004 0x2c04 11268 PS04: Invalid MCI par. set Fault - 0x6300
4xx.0144.00007 0x2c07 11271 PS07: Invalid memory module par. set Fault - 0x6300
Error number
Error message
Response
(Lenze setting)
can be set in
32 bits
16 bitshex
16 bitsdec
4xx.0144.00008
0x2c08
11272
PS08: Invalid device par.
Fault
0x6300
4xx.0144.00009
0x2c09
11273
PS09: Invalid par. format
Fault
0x6300
4xx.0144.00010
0x2c0a
11274
PS10: Memory module binding invalid
Fault
4xx.0123.00205
0x17cd
6093
Sd3: Feedback system open circuit
Fault
C00586
0x7300
4xx.0123.00200
0x17c8
6088
Sd10: Speed limit for feedback system 12
Fault
C00607
0x7300
4xx.0123.00201
0x17c9
6089
Sd11: Speed limit for feedback system 67
Fault
C00607
0x7300
4xx.0111.00002
0x0b02
2818
Su02: One mains phase is missing
Warning
C00565
0x3000
4xx.0111.00003
0x0b03
2819
Su03: Too frequent mains switching
Fault
0x3000
4xx.0111.00004
0x0b04
2820
Su04: CU insufficiently supplied
Fault
0x3000
4xx.0111.00006
0x0b06
2822
Su06: Mains input overload
Fault
0x3000
4xx.0980.00001
US01: User error 1
No Reaction
C00581/1
0x6200
4xx.0981.00002
US02: User error 2
No Reaction
C00581/2
0x6200
4xx.0982.00003
US03: User error 3
No Reaction
C00581/3
0x6200
4xx.0983.00004
US04: User error 4
No Reaction
C00581/4
0x6200
4xx.0984.00001
US05: User error 5
No Reaction
C00581/5
0x6200
4xx.0985.00002
US06: User error 6
No Reaction
C00581/6
0x6200
4xx.0986.00003
US07: User error 7
No Reaction
C00581/7
0x6200
4xx.0987.00004
US08: User error 8
No Reaction
C00581/8
0x6200
