COL fault in LS dri...
COL fault in LS drive
Cause : Input phase loss comes when inverter output is blocked when one of R, S, T is open or the electrolytic capacitor needs to be replaced.
Input phase loss comes when input R,S,T have phase loss or imbalance. An Input Phase Loss "COL" fault will occur when the DC bus ripple exceeds a pre-defined level. One (or more) of the input phases were lost.
  1. Large imbalance of voltage exists on the input of the drive.
  2. Drive is not properly sized for single phase input.
  3. Check input voltage.
  4. Check rectifier section using multimeter.
