LS Drives
654
Apr 13, 2024 11:45 am
Cause : Electronic Thermal comes when the internal electronic thermal of the inverter determines the overheating of the motor. If the motor is overloaded the inverter turns off the output. The inverter cannot protect the motor when driving a motor having more than 4 poles or multi motors.
- Motor has overheated.
- Reduce load weight and operating duty.
- Load is greater than inverter rating. ETH level is set too low.
- Change inverter with higher capacity.
- Inverter capacity is incorrectly selected. Inverter has been operated at low speed for too long.
- Select correct inverter capacity.
