IOL fault in LS dri...
IOL fault in LS drive
Cause : Inverter Overload comes when the inverter turns off its output when the output current of the inverter flows more than the rated level (150% for 1 minute).
  1. Load is greater than the inverter rating.
  2. Upgrade the capacity of motor and inverter or reduce the load weight.
  3. Torque boost scale is set too large.
  4. Reduce torque boost scale.
