overcurrent fault i...
overcurrent fault in LS drive
Cause : Overcurrent comes when the power unit has detected an overcurrent condition. If you're experiencing an overcurrent fault with LS drive, it indicates that the current flowing through the motor exceeds the permissible limit set by the drive's protection settings.
"Overcurrent fault" in "LS drive" indicates that the current drawn by the motor has exceeded the drive's limit. This means the load on the motor is greater than the drive's rated capacity.
Common Causes of "Overcurrent Fault in LS drive"
1. Motor Overload:
4. Motor or Cable Issues:
5. Drive Fault:
Diagnostic Steps:
  1. Check Motor Load:
  2. Verify Parameter Settings:
  3. Inspect Motor and Cables:
  4. Monitor Drive Status:
