LS L100, S100, iG5A & iV5L Drive
693
Apr 13, 2024 10:54 am
Cause : Over voltage comes when the inverter turns off its output if the DC voltage of the main circuit increases higher than 400 V when the motor decelerates. This fault can also occur due to a surge voltage generated at the power supply system.
- Increase the Decel time.
- Regenerative load is at the inverter output.
- Use Dynamic Brake Unit.
- Line voltage is too high.
- Check whether line voltage exceeds its rating.
