GFt fault in L&T CX2000 drive
Cause : Ground fault current comes when the inverter turns off its output when a ground fault occurs and the ground fault current is more than the internal setting value of the inverter.
  1. Ground fault has occurred at the output wiring of the inverter- Check the wiring of the output terminal.
  2. The insulation of the motor is damaged due to heat- Check motor wiring and earthing.
