L&T CX2000, EX2000, FX2000 & HX2000 Drive
507
Apr 13, 2024 12:03 pm
Cause : Inverter overheat comes when the inverter turns off its output if the heat sink overheats due to a damaged cooling fan or an alien substance in the cooling fan by detecting the temperature of the heat sink.
- Cooling system has faults.
- Check for alien substances clogged in the heat sink.
- An old cooling fan is not replaced with a new one.
- Replace the old cooling fan with a new one.
- Ambient temperature is too high.
- Keep ambient temperature under 50°C.
