Cause : Overvoltage comes when the voltage within the drive has exceeded its safe operating limits due to the voltage coming from your power source is too high for the drive to handle.
The F0002 fault code on a Siemens Micromaster 420 (MM420) indicates an overvoltage condition. This means that the voltage on the DC link has exceeded the permissible limit.
- Check whether the supply voltage is within the limits indicated on the rating plate.
- Check if dc-link voltage controller (P1240) is enabled and parameterized correctly.
- Increase the ramp-down time (P1121).
Here are some steps to diagnose and resolve this issue:
Check Supply Voltage:
- Verify that the supply voltage is within the specified range for the MM420. Excessive supply voltage can cause overvoltage faults.
- Ensure that there are no sudden spikes or surges in the supply voltage.
Inspect Deceleration Time:
- If the drive is decelerating too quickly, the regenerative energy from the motor can cause a temporary increase in DC link voltage.
- Increase the deceleration time parameter to allow for a slower deceleration, reducing the likelihood of an overvoltage condition.
Brake Chopper and Resistor:
- If the drive has a brake chopper and braking resistor installed, ensure that they are functioning correctly. A faulty brake chopper or resistor can prevent proper dissipation of excess energy, leading to overvoltage.
- Verify the connection and sizing of the braking resistor.
Check for External Factors:
- Ensure that there are no external factors causing voltage spikes, such as nearby heavy machinery switching on or off.
- Consider using surge protection devices to protect against transient overvoltage conditions.
Review Drive Settings:
- Check the drive parameters related to voltage limits and braking. Ensure that they are set appropriately for your application.
- Key parameters to check include:
- DC link voltage limit
- Brake chopper activation threshold
Environmental Factors:
- Ensure that the drive is operating within its specified temperature range and that adequate cooling is provided. Overheating can exacerbate voltage issues.
Monitoring:
- Use the drive's monitoring functions to observe the DC link voltage during operation. This can help identify patterns or specific conditions that lead to the overvoltage fault.
Reset the Drive:
- After addressing any identified issues, reset the drive to clear the fault. This can typically be done by cycling power or using the reset function on the drive.
