F0222 fault in siemens micromaster 420 drive
Cause : PI Feedback above maximum value comes when drive isn't receiving a proper feedback signal from the motor, or the PID control settings are not configured correctly. This fault comes when PI Feedback above maximum value P2267.
The fault code F0222 on a Siemens Micromaster 420 (MM420) indicates a proportional-integral (PI) feedback below the minimum value fault. This fault typically occurs in closed-loop control systems where the drive expects feedback from a sensor to maintain speed or position control, but the received feedback falls above the maximum acceptable threshold.
  1. Change value of P2268.
  2. Adjust feedback gain.
