Siemens Micromaster 440 or MM440 Drive
1,096
Oct 23, 2024 5:16 am
siemens mm440 fault codes - Easy to understand guide for diagnosing and fixing common drive faults. Improve equipment uptime.
Below list show siemens mm440 fault codes:
- F0005 Inverter overload fault in siemens micromaster 440 drive - Cause : when inverter overloaded or the motor power rating is greater than that of the inverter.
- F0004 Inverter temperature fault in siemens micromaster 440 drive - Cause - comes when ambient temperature is too high or IGBT is overload or cooling fan is faulty.
- F0003 Undervoltage fault in siemens micromaster 440 drive - Cause - Undervoltage comes when line voltage failed or input supply voltage is less as compare to supply voltage of drive.
- F0002 Overvoltage fault in siemens micromaster 440 drive - comes when DC link voltage (r0026) higher than the overvoltage threshold or high input supply.
- F0001 Overcurrent fault in siemens micromaster 440 drive - comes when short-circuit at the output or ground fault or excessively large motor.
- F0085 External fault in siemens micromaster 440 drive -Â comes when external fault as a result of command input via terminals.
- F0080 ADC fault fault in siemens micromaster 440 drive - comes when ADC input signal lost or wire breakage.
- F0072 fault in siemens micromaster 440 drive - comes when no setpoints received via the USS during the telegram off time.
- F0071 fault in siemens micromaster 440 drive - comes when no response during telegram off time via USS (BOP link).
- F0070 fault in siemens micromaster 440 drive - comes when no set-point received via the communications bus during the telegram failure time.
- F0060 Communication fault in siemens micromaster 440 drive - comes when internal communications failure/error or faulty control card of drive.
- F0052 Power stack fault in siemens micromaster 440 drive - comes when reading of the power stack information has failed or the data is invalid.
- F0051 Parameter EEPROM fault fault in siemens micromaster 440 drive - comes when read or write operation while saving parameters in the EEPROM was unsuccessful.
- F0041 fault in siemens micromaster 440 drive - comes when motor data identification run unsuccessful due to load missing or current limit value reached during identification.
- F0011 Motor overtemperature I2T fault in siemens micromaster 440 drive - comes when motor overloaded or incorrect motor data in parameter.
This is a comprehensive list of siemens mm440 fault codes. Quickly troubleshoot and resolve common issues.
