E. 1 to E. 3 fault error code in Mitsubishi A700 drive
Cause : Option fault comes when the inverter trips when a contact fault is found between the inverter and the plug-in option, or when the communication option is not connected to the connector 1.
Appears when the switch for manufacturer setting of the plug-in option is changed.
  1. Check that the plug-in option is plugged into the connector properly.
  2. Check for excessive noise around the inverter.
  3. Check if the communication option is connected to the connector 2 or 3.
  4. Connect the plug-in option securely.
  5. Connect the communication option to the connector 1.
