347
Mar 30, 2024 7:52 am
Cause : Converter overcurrent comes when the current flows in the regeneration converter module exceeds the specified value, protective circuit activates and stops the inverter output.
- Check that sudden acceleration/deceleration is not performed.
- Check for sudden load change.
- Check that wiring is correct.
- Check that instantaneous power failure did not occur.
- Check that the thyristor load does not exist in the same power supply system.
