E.BE fault error code in Mitsubishi A700 drive
Cause : Brake transistor alarm detection comes when the inverter trips if a fault due to damage of the brake transistor and such occurs in the brake circuit. In such a case, the power supply to the inverter must be shut off immediately.
  1. Reduce the load inertia.
  2. Check that the brake duty is proper.
  3. Replace the inverter.
