E.MB1 to 7 fault error code in Mitsubishi A700 drive
Cause : Brake sequence fault comes when the inverter output is stopped when a sequence error occurs during use of the brake sequence function (Pr. 278 to Pr. 285). This fault is not available in the initial status (brake sequence function is invalid).
  1. Find the cause of alarm occurrence.
  2. Check the set parameters and perform wiring properly.
