E.OP3 fault error code in Mitsubishi A701 drive
Cause : Communication option fault comes when a communication line error occurs in the communication option. Check for a wrong option function setting and operation.
  1. Check that the plug-in option is plugged into the connector securely.
  2. Check that the terminating resistor is fitted properly.
  3. Check for a break in the communication cable.
