E.THT fault error code in Mitsubishi A701 drive
Cause : Inverter overload trip comes when the current not less than 150% of the rated output current flows and overcurrent trip does not occur (220% or less), the electronic thermal relay activate to stop the inverter output in order to protect the output transistors. (Overload capacity 150% 60s inverse-time characteristics)
  1. Check that acceleration/deceleration time is not too short.
  2. Check that torque boost setting is not too large (small).
  3. Check that load pattern selection setting is appropriate for the load pattern of the using machine.
  4. Check the motor for the use under overload.
  5. Set the acceleration/deceleration time longer.
  6. Adjust the torque boost setting.
  7. Set the load pattern selection setting according to the load pattern of the using machine.
