E.USB fault error code in Mitsubishi A701 drive
Cause : USB communication fault comes when the inverter trips when the communication is cut off for the time set in Pr.548 USB communication check time interval.
  1. Check that the USB communication cable is connected securely.
  2. Check the Pr.548 setting.
  3. Connect the USB communication cable securely.
  4. Increase the Pr.548 setting or set "9999."
