MT fault error code in Mitsubishi A700 drive
Cause : Maintenance signal output comes when the cumulative energization time of the inverter has reached a given time. When the setting of Pr. 504 Maintenance timer alarm output set time is the initial value (Pr. 504 = "9999"), this warning does not occur.
  1. The Pr. 503 Maintenance timer setting is larger than the Pr. 504 Maintenance timer alarm output set time setting.
  2. Setting "0" in Pr. 503 Maintenance timer erases the signal.
