MT1 to MT3 fault warning in Mitsubishi A800 drive
Cause : Maintenance signal output 1 to 3 comes when the inverter's cumulative energization time reaches or exceeds the parameter set value. Set the time until the MT is displayed using Pr.504 Maintenance timer 1 warning output set time (MT1), Pr.687 Maintenance timer 2 warning output set time (MT2), and Pr.689 Maintenance timer 3 warning output set time (MT3).
  1. MT does not appear when the settings of Pr.504, Pr.687, and Pr.689 are initial values (9999).
  2. The set time of maintenance timer has been exceeded.
  3. Take appropriate countermeasures according to the purpose of the maintenance timer setting. Setting "0" in Pr.503 Maintenance timer 1, Pr.686 Maintenance timer 2, and Pr.688 Maintenance timer 3 clears the indication.
Click2Electro
Get free chat support...
🟢 Online
