225
Mar 29, 2024 12:38 pm
Cause : Parameter verification error comes when the data in the inverter are different from the data in the operation panel.
- A failure has occurred at the operation panel side EEPROM during parameter verification.
- A failure has occurred in the USB memory device during parameter verification.
- The data in the inverter are different from the data in the USB memory device or the personal computer (FR Configurator2).
- Check the parameter setting of the source inverter against the setting of the destination inverter.
- Continue the verification by pressing SET.
- The operation panel (FR-DU08) may be faulty.
- The USB memory device may be faulty. Replace the USB memory device.
- Verify the PLC function project data again.
