SL fault error code in Mitsubishi A700 drive
Cause : Speed limit indication comes when output if the speed limit level is exceeded during torque control. Check that the torque command is not larger than required. Check if the speed limit level is set too low.
  1. Decrease the torque command value.
  2. Increase the speed limit level.
Click2Electro
Get free chat support...
🟢 Online
