520
Apr 02, 2024 12:40 pm
Cause : Option fault comes when the converter output is shut off when a contact failure occurs between the converter and the communication option.
Appears when the switch for manufacturer setting on the communication option is changed.
• Check that the communication option is plugged into the connector securely.
• Check for excess electrical noises generated around the converter.
• Check that the initial position of the switch for manufacturer setting was not changed.
