469
Apr 02, 2024 11:55 am
Cause : Output phase loss comes when the inverter trips if one of the three phases (U, V, W) on the inverter's output side (load side) is lost.
- Check the wiring. (Check that the motor is normally operating.)
- Check that the capacity of the motor used is not smaller than that of the inverter.
- Check if a start command is given to the inverter while the motor is coasting.
- Wire the cables properly.
