E.M fault error code in Mitsubishi FR-XC drive
Cause : 24 VDC power output short circuit comes when the 24 VDC power output from terminal PC is shorted, this function is activated to shut off the power output.
At this time, all external contact inputs turn OFF. The converter cannot be reset by inputting the RES signal via an external terminal. To reset the converter, use the PU, or turn the converter power OFF and ON again.
