E. Q fault error code in Mitsubishi FR-XC drive
Cause : Communication option fault comes when the converter output is shut off if a communication line error occurs in the communication option.
• Check for a wrong option function setting and operation.
• Check that the communication option is plugged into the connector securely.
• Check for a break in the communication cables.
• Check that the terminating resistor is fitted properly.
