424
Apr 02, 2024 12:18 pm
Cause : Power supply not detected comes when the power supply detection ends incompletely at a power failure. This fault comes at the power ON of the control circuit when using separate power supply sources for the control circuit power supply and for the main circuit power supply. It is not a fault.
- Check that the wiring from proper power source is performed correctly.
- Check that the wiring is performed correctly so that the power source can be detected.
