rE4 fault error code in Mitsubishi FR-XC drive
Cause : Product series error comes when the series of the source converter used to copy or verify parameters is not the same as the target converter.
The operation panel data was incorrect when attempting to verify parameters or copy parameters from the operation panel to the converter.
  1. Check that the source converter being used to verify or copy parameters is the same series as the target converter.
  2. Check that the copying of parameters was not interrupted due to a loss of power to the converter or the operation panel being disconnected.
  3. Try to copy or verify parameters.
Click2Electro
Get free chat support...
🟢 Online
