472
Apr 02, 2024 9:05 am
Cause : Option fault comes when the inverter output is shut off when a contact failure occurs between the inverter and the plug-in option. Appears when the switch for manufacturer setting of the plug-in option is changed
- Check that the plug-in option is plugged into the connector properly.
- Check for excessive noise around the inverter.
- Check if the communication option is connected to the connector.
- Connect the plug-in option securely.
- Connect the communication option to the connector.
Â
