E.10 fault error code in Mitsubishi E800 drive
The inverter output is shut off if the inverter detects an output current fault such as an earth (ground) fault that occurred on the inverter's output side (load side).
  1. Check for an earth (ground) fault in the motor and connection cable.
  2. Remedy the earth (ground) fault or other fault.
Click2Electro
Get free chat support...
🟢 Online
