E.11 fault error code in Mitsubishi E800 drive
Cause : Opposite rotation deceleration fault comes when the speed may not decelerate during low speed operation if the rotation direction of the speed command and the estimated speed differ when the rotation is changing from forward to reverse or from reverse to forward during torque control under Real sensorless vector control.
  1. The inverter trips when overload occurs due to the un-switched rotation direction. This protective function is not available in the initial status (V/F control). (This function is only available under Real sensorless vector control.)
  2. Check that the rotation direction is not switched from forward to reverse rotation.
  3. Prevent the motor from switching the rotation direction from forward to reverse (or from reverse to forward) during torque control under Real sensorless vector control.
