1,513
Apr 02, 2024 9:31 am
Cause : Brake transistor alarm detection comes when the inverter trips if a fault due to damage of the brake transistor and such occurs in the brake circuit. In such a case, the power supply to the inverter must be shut off immediately.
- Appears when an internal circuit fault occurred.
- Reduce the load inertia.
- Check that the brake duty is proper.
- Replace the inverter.
