E.BE fault error code in Mitsubishi E800 drive
Cause : Brake transistor alarm detection comes when the inverter trips if a fault due to damage of the brake transistor and such occurs in the brake circuit. In such a case, the power supply to the inverter must be shut off immediately.
  1. Appears when an internal circuit fault occurred.
  2. Reduce the load inertia.
  3. Check that the brake duty is proper.
  4. Replace the inverter.
