E.IAH fault error code in Mitsubishi E800 drive
Cause : Abnormal internal temperature comes when the inverter trips when the inverter internal temperature reaches the specified value or higher.
  1. Check for too high surrounding air temperature.
  2. Check if the internal air circulation fan or the cooling fan stops due to a fault.
  3. Install an inverter suitable for the installation environment.
  4. Replace the internal air circulation fan or the cooling fan.
