E.MB1 to 7 fault error code in Mitsubishi E800 drive
Cause : Brake sequence fault comes when the inverter trips when a sequence error occurs during use of the brake sequence function (Pr.278 to Pr.285). This protective function is not available in the initial status. (The brake sequence function is invalid.)
  1. Find the cause of the fault occurrence.
  2. Check the set parameters and perform wiring properly.
