E.OD fault error code in Mitsubishi E800 drive
Cause : Excessive position fault comes when the inverter trips when the difference between the position command and position feedback exceeds Pr.427 Excessive level error under position control.
  1. Check that the position detecting encoder mounting orientation matches the parameter.
  2. Check that the load is not large.
  3. Check that the Pr.427, Pr.369 Number of encoder pulses settings are correct.
  4. Check the parameters.
