E.OP1 fault error code in Mitsubishi E700 drive
Cause : Communication option fault comes when the inverter trips if a communication line error occurs in the communication option.
  1. Check for an incorrect option function setting and operation.
  2. Check that the plug-in option is plugged into the connector properly.
  3. Check for a break in the communication cable.
  4. Check that the terminating resistor is fitted properly.
  5. Check the option function setting, etc.
  6. Connect the plug-in option securely.
