IP fault error code in Mitsubishi E800 drive
Appears when the IP address or the subnet mask is out of the specified range. Check that "0 or 255" is not set in the third or fourth octet of the IP address.
  1. Check that the subnet mask setting is appropriate.
  2. Check that the IP address settings are correct.
  3. Set "1 to 254" in the third or fourth octet of the IP address.
  4. Set the subnet mask (Pr.1438 to Pr.1441) correctly.
  5. Set the IP address (Pr.1434 to Pr.1447) correctly.
