PS fault error code in Mitsubishi E800 drive
Cause : PU stop comes when the motor is stopped using STOP/RESET button under the mode other than the PU operation mode. (To enable STOP/RESET button under the mode other than the PU operation mode, set Pr.75 Reset selection/disconnected PU
detection/PU stop selection.
  1. Check for a stop made by pressing STOP/RESET button of the operation panel.
  2. Check for whether the X92 signal is OFF.
  3. Turn the start signal OFF and release with PU/EXT .
  4. Turn ON the X92 signal and OFF the start signal for release.
