1,125
Apr 02, 2024 9:24 am
Cause : Undervoltage comes when the power supply voltage of the inverter decreases, the control circuit will not perform normal functions. In addition, the motor torque will be insufficient and/or heat generation will increase. To prevent this, if the power supply voltage decreases below about 115VAC (about 230VAC for 400V class), this function stops the inverter output and displays UV.
- An alarm is reset when the voltage returns to normal.
- Check that the power supply voltage is normal.
- Check the power supply system equipment such as power supply.
