E. 1 fault error code in Mitsubishi F700
Cause : Option fault comes when the inverter output if a contact fault or the like of the connector between the inverter and communication option occurs.
Appears when the switch for the manufacturer setting of the plug-in option is changed.
1. Check that the plug-in option is plugged into the connector securely.
2. Check for excess electrical noises around the inverter.
